error code 54
I need assistance with error code 54, what to look for and how to clear the code after it's repaired, thanks for the help.
  • Posted 8 Oct 2008 07:49
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
Thanks for the info, we found an open wire.
  • Posted 11 Nov 2008 23:56
  • By cownd
The code is a swing solenoid abnormality. I would start by checking the wiring at the w=swing lock solenoid and if it is fine there check all harness connectors. You can clear codes by disconnectiong the negative cable for about 1min.
  • Posted 11 Nov 2008 11:46
  • By rogeriwt
Elwell-Parker ESI500-36
Terberg YT220
Libiao Robotics
