No hydraulic functions
Hello ,
The problem is with aLinde E 16C , 335- 02 series.The hidraulic functions is not working , the steering not working.
On the truck doctor at window (2) of lifting diagnose -( instant errors )it show me "19" error that say joystick must be teach- in.( i tryed to calibrate the lift / tilt joystick and stored the "ok" values , but in that window the " 19" error still apear..
At window( 3 )(fault code stored) in truck doctor , after i erase all errors , when i activate the lift / tilt joystick , apear error "29".The drive is working , the baterry is 50% charged , seat switch ok , cabin switch ok , hidraulic motor conexions ok , brush ok.
What cause can be ? It may be the power module ?
Thanks ,
Regards ,
Gabi
  • Posted 4 Dec 2020 03:27
  • By gabi_g
  • joined 1 May'13 - 90 messages
gabihdh at gmail dot com
98% the powermodule give problem. It is integrated in the left drive module and a expensive part.
  • Posted 4 Dec 2020 08:06
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Thanks.Next week i will check also the insulance of electric motor.I don' t know if i can simulate the electric motor with 2 , 24 v in series , lightbulb.I supose that when i make the joystick command a fraction of a second should light the bulbs.The problem is that the engine has a speed sensor..and that I can't simulate
  • Posted 4 Dec 2020 07:39
  • By gabi_g
Hello , yes power module on leftside of counterweight defect. Before replace check cables and hydraulic motor
  • Posted 4 Dec 2020 06:52
  • By tr_doctor
  • Netherlands
Regards
Michel Denis Michel Denis
Taylor T650L
Maxlion R2D35
