Baker FMA 030
Have a chance to buy a Baker FMA 030 forklift for $1,000. Looking for expert perspectives as to parts availability / dependability / overall. I have an automotive custom shop and would be using it in and around. Thanks for you time and assistance in advance. Mike
  • Posted 11 Jun 2020 05:19
  • By Hickmaster2001
  • joined 11 Jun'20 - 16 messages
  • Maryland, United States
Showing items 1 - 19 of 19 results.
Some people have found parts manuals for this model online. The Baker # for the transmission should have a 9020 in it, like A9020.... It was probably made by Borg Warner and would use ATF.
You should be able to get the parts from Joseph Industries in Ohio. If you have the Baker # for the trans then they can help you indentify any parts.
  • Posted 23 Dec 2022 00:20
  • By duodeluxe
  • United States
duodeluxe
Duodeluxe, I have a 1972 FJF-040 Military fork lift. Has a Baker Trans model 102166 I need to find clutch disc part #'s and also I have found 2 different things stating the type of trannu fluid. One says Type A trans fluid and one says 10 weight fluid. Do you happen to jnow which one it takes and a part # for the clutch disc?
  • Posted 18 Dec 2022 11:18
  • By BetheaAuto
  • joined 18 Dec'22 - 1 message
  • Alabama, United States
BetheaAuto
Duodeluxe, thanks! will keep looking and reach back out when I have another candidate. Can't thank you enough for the expert advice! Mike
  • Posted 19 Jun 2020 21:45
  • By Hickmaster2001
I'd pass on it. It is either a pre 1967 model or military surplus. Either way almost all of the parts have been no longer available for quite some time. If you want something with pneumatic tires for outdoor use you will have to raise your budget substantially.
  • Posted 19 Jun 2020 21:15
  • By duodeluxe
  • United States
duodeluxe
Can't make out the serial number in the pictures.
4 Cylinder Continental Engine (claimed to be recently rebuilt)
Asking $2,500 (seems high in price?)
-Mike
  • Posted 19 Jun 2020 03:21
  • By Hickmaster2001
What is the serial #? If you don't know, does it have a 4 or 6 cylinder engine? How much $?
  • Posted 18 Jun 2020 23:44
  • By duodeluxe
  • United States
duodeluxe
UPDATE, went to see the cark and it was a bit more of a project than anticipated so I passed. Major item of concern for was the mast would not stay up and would need diagnosis/repair. Also in discussions with the owner, a Fork Truck tech, I have decided to look for a more off road capable truck. Found a Baker FJF-040 and was wondering if anyone had any thoughts... At this point I am all over the map and very thankful for those who have been responding as it will help me make a better informed purchase. Google gave me a thread on this board that was pretty recent concerning brake repairs so at least others have these machines and are keeping them going. Thanks again! Mike
  • Posted 18 Jun 2020 23:27
  • By Hickmaster2001
Keep bag of oil-dry nearby to tend with hydraulic leaks now and then
On bright side, LP gas truck will run fairly long time. Good Luck
  • Posted 18 Jun 2020 22:59
  • By FMar
  • joined 4 Jan'18 - 12 messages
FMar4lift
Duodeluxe, the one available to me is the 1882. I am likely going to grab the Clark as its even cheaper, newer, and running. Appreciate all the info, please keep it coming. Mike
  • Posted 13 Jun 2020 03:17
  • Modified 13 Jun 2020 03:17 by poster
  • By Hickmaster2001
I was a Baker dealer since 1972. The Borg Warner transmissions were bullet proof. We only rebuilt one, ever. Most of the wear items for this truck are still available. The one item that is not available which would be a big issue is the drive wheel hubs. Most people that worked on these trucks didn't tighten the drive axle nut enough and the key on the axle shaft would be loose causing the key way in the hub to wear and/or crack the hub.
These trucks were available in two series, one with 1882 in the serial # and the other had 1911 in it. The 1911 was a much better truck.
  • Posted 13 Jun 2020 03:01
  • By duodeluxe
  • United States
duodeluxe
The C500 Clark's were about as bullet proof as they come. Parts are still available for the most part.
  • Posted 13 Jun 2020 01:19
  • By larry_w
  • joined 13 Feb'15 - 6 messages
Larry L Wise
Thanks to everyone for their time and knowledgeable responses. Based upon the lack of parts availability mentioned I may pass on this truck because I am certain an older machine will need some kind of parts replacement along the way. Anyone have any thoughts on a Clark C500-50? Looks to be a 1978 model? From a short Google search it looks like better parts availability. Please let me know your thoughts. Thanks again for the help! Mike
  • Posted 12 Jun 2020 23:13
  • By Hickmaster2001
I was a Baker Mechanic in the early 1980's when Linde came over with their Electric BCE 5K and BTE 3wheel. The Bakers gas trucks back then came out of Cleveland and they were great trucks but I would steer clear of them now because of no parts availability. Unless you can buy two of them and use one as a parts donor but that still would be a crap shoot!
  • Posted 12 Jun 2020 08:01
  • By OldTechGuy
  • joined 1 Oct'10 - 19 messages
  • Illinois, United States
Make sure the trans is good. It's got the small Borg Warner in it and the parts for it for the most part aren't available. Check the steer axle, spindles, center plate, again, not available. Bearings are. It should have a Y112 Continental engine, again, mostly obsolete for internal hard parts. Maybe even water pump not available, possibly rebuildable. It's like any other $1,000 lift, it's a crap shoot. If it's generally in decent condition, you probably will get your monies worth out of it, but it is a gamble.
  • Posted 12 Jun 2020 01:46
  • By larry_w
Larry L Wise
Gents, thank you for your feedback! Anything to look for specifically you can think of as far as wear items that commonly need replacement and that would be hard to find? Just trying to make sure I don't get into a machine that is too hard to maintain. It will not see constant use so, as long as I can keep it maintained I don't imagine wearing it down much in the few years I plan to operate it. Please let me know your thoughts... Thanks again!
  • Posted 12 Jun 2020 01:17
  • By Hickmaster2001
Definitely a good truck in its day. Parts support from Linde, formerly Baker, is non-existent for this lift. Some soft parts are still available after market, but hard parts are basically not available unless you're fortunate enough to find them at a scrap forklift dealer.
  • Posted 12 Jun 2020 00:06
  • By larry_w
Larry L Wise
It was a good forklift truck in its day. Most likely early to late 1970's. Believe it or not a lot of the parts are still available.
  • Posted 11 Jun 2020 23:55
  • By duodeluxe
  • United States
duodeluxe
Thanks for the feedback Fred. VERY helpful.
  • Posted 11 Jun 2020 22:52
  • Modified 11 Jun 2020 23:21 by poster
  • By Hickmaster2001
LOL!!
  • Posted 11 Jun 2020 22:49
  • By Fred
  • joined 11 Jun'20 - 1 message
  • Connecticut, United States
The Truck Guy
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
USD1
