will stop moving after a while.
it I rev engine up, it will take off, but if you take it easy it wont move in all directions. any direction to look into would be helpful
  • Posted 5 May 2020 03:11
  • By Steven_K
  • joined 20 Feb'20 - 3 messages
stevek
As long as the electrical control side of the drive system is working correctly it sounds like a bypassing drive unit. To check for a bad unit remove the case drain line inbetween the two main drive hoses on the back of the motor. Run a new line from the drive units case drain into a bucket. Measure amount of fluid coming out of the case drain line. If its more than 1L every couple mins then the unit is bypassing internally. Repeat same procedure for the other drive units on the truck.
Best to do so when the truck isnt moving when a drive direction is selected.
Keep in mind the unit may not bypass if the wheel is lifted off the ground.
  • Posted 26 Aug 2020 22:30
  • Modified 26 Aug 2020 22:31 by poster
  • By BLey
  • joined 31 Jul'20 - 59 messages
Try tightening the hydraulic filter. Have a tendency to come loose.
  • Posted 26 Aug 2020 17:24
  • By CHRISCARRYLIFT
  • joined 18 Mar'08 - 24 messages
  • 0000, United Kingdom
Hi
If you can email Combilift Technical group they will support you, or go to the Combilift web site and select Service and then select Technical.
Hope this help you solve this problem and help with future support.
Thanks Richard
  • Posted 3 Jul 2020 18:01
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Sue Tomic Sue Tomic
Taylor X550M
Terberg RT223
Bolzoni SpA (Group HQ)
Sue Tomic Sue Tomic
