P03 and P07 Fault codes
Hi has anyone had these fault codes before? I know they are both communication errors and have checked everything i can think of. Even tried swapping VCM with another identical unit.
Have checked loom can see any issue there.
Thanks brad
  • Posted 26 Apr 2020 11:06
  • By Brad43
  • joined 11 Oct'12 - 23 messages
  • New Zealand, New Zealand
It's a older unit. Lift works fine just jeeps popping up these codes.
  • Posted 1 Jun 2025 02:29
  • By Justaguy75
  • joined 27 May'23 - 5 messages
  • Alabama, United States
Not sure if that harness would work in a 1F4 model. I only encountered that issue in the 1F2 models. Does your dash turn off as soon as you shut the key off? Unicarriers tech service told me back then that it wouldn't cause any harm. Is this a new unit or did it just start happening all of a sudden? If it is a used unit then it is probably something else causing that problem.
  • Posted 1 Jun 2025 02:05
  • By mwjago
  • joined 20 Apr'25 - 15 messages
  • Montana, United States
mwjago
Where does this harness plug in at? Thanks. Also the lift I am working on is a mw1f4a45v with p03 and p07 codes. Does this harness work for this lift also?
  • Posted 30 May 2025 05:44
  • Modified 30 May 2025 05:46 by poster
  • By Justaguy75
Hello Keith; That p/n for the repair harness that causes the P07 code is 24027-FV50A When it first came out Unicarriers only had about 6 on hand, and that was years ago. I'm retired now so maybe they have more on hand now. Good luck!!!
  • Posted 28 Nov 2023 13:46
  • By mwjski
  • joined 26 Jan'18 - 33 messages
I have 2 units in our territory that are giving these codes. do you happen to have the part # that unicarriers sells for this situation?
  • Posted 25 Jul 2023 06:03
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
Your dash monitor is probably shutting off when you turn the key off. Your VCM still holds power for a few seconds and cannot communicate with the monitor therefore causing your P07 code. The newest trucks keep power to the monitor so the two can communicate with each other. This code is not harmful to the but is more of just a pain because it keeps coming up all the time. Nissan makes a sub harness to install to keep power to the dash monitor for about 3 seconds.
  • Posted 8 May 2021 05:19
  • By mwjski
