replacement vaporizer w.c.
I have an old C20B that was converted to some point to LP.
I believe I had a bad vaporizer. The lift would start usally, and the vaporizer would freeze up. Could get it to run ok for 20-30 second if I shut off the tank. Also when key was turned and the cut-off was open, you could hear a hiss from the intake filter.
The vaporizer on it was a Nolff's model N-J
I got a Century Fuel Products C-Cobra-1 as a replacement.
I notice that the Nolff's list W.C. of.2LBS and the Cobra lists it as W.C.0.08LBS. Seems like every other one I see on-line is also the.08LBS.
I can not find much information on that spec to understand if it is an issue or not.
Any help or insight appreciated.
Thanks,
Scott
  • Posted 29 Mar 2020 02:54
  • By sallred
  • joined 6 Dec'13 - 7 messages
  • Missouri, United States
Need the forklift serial number if possible
  • Posted 30 Mar 2020 10:45
  • By tom_p
  • Alberta, Canada
The serial number in the Nolff's is 124752.
Scott
  • Posted 30 Mar 2020 02:03
  • By sallred
Full ser # please
  • Posted 29 Mar 2020 11:20
  • By tom_p
  • Alberta, Canada
edition #1257 - 20 November 2025
HD Hyundai XiteSolutions receives order for 230 forklifts Caracas, Venezuela, Bolivarian Republic Of
