No forward + Reverse
We have the following truck stuck in the middle of the warehouse where it was dumped on a pallet by a courier. Its a BT S10, originally throwing a C28 when actuating the lift button this has now resolved and the fork lift mechanism works as it should.
The current issue is the pallet truck will not move forward nor reverse. When actuating there is not clicks or anything of the sort nor is there any error codes.
wiring has been checked, the two contactors appear to be working (pump + main), fuses are ok...have scoped out the CAN lines for the logic board and they appear to be ok.
any suggestions?
  • Posted 17 Mar 2020 05:57
  • By 3staar
  • joined 17 Mar'20 - 1 message
  • Yorkshire, United Kingdom
Have you checked the switch in the steering arm?
When pulling down you should hear a click of the main contactor.
Also sometimes the elektromagnetic brake disc can be stuck.
Loosen the brake at top of the motor and see if motor will turn
Good luck
  • Posted 3 Sep 2020 09:46
  • By LionKing
  • joined 15 Mar'15 - 24 messages
  • Groningen, Netherlands
d.gruis@home.nl
Komatsu FD25T17
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
