Voltage problem
1 week ago, the battery was replaced. Called back for a "no start" again. Jumped it to start and charging volts were 9.3v...rev the engine and voltage actually dropped to 8.1v. Ordered and installed an alternator. Battery showed 0v. Went to jump start and got a huge arc on the cable. Cables got warm and no power to key. Took the positive cable off and the battery volts started to climb. Put the cable back on and it dropped to zero volts again. What is going on?
  • Posted 29 Feb 2020 12:20
  • By Ifixit
This is the Veracitor model, and the fuse/relay box got corroded and shorted to negative
  • Posted 11 Mar 2020 12:23
  • By Ifixit
there is a 60 amp alternator mega fuse, make sure you're fuse is good. disconnect the negative terminal and reconnect after charging the battery, is there a large spark when connecting the battery with the key off?
  • Posted 5 Mar 2020 04:55
  • By JtothemfMill
  • joined 5 Mar'20 - 3 messages
EVERYTHING is figureoutable
Remove positive cable off of battery. Take a standard 12v test light. Hook gator clip to cable, then take light end and touch it back to positive post on battery. If test light lights up, up have a draw somewhere. Bare in mind, i have seen bad new batteries, starters ,and alternators.
Removing the hot wire from starter and alternator from each, one at a time, will eliminate whether they have shorted or not. Bad battery cables can also cause severe voltage drop. Especially when loaded.
  • Posted 2 Mar 2020 00:23
  • By James_Lott
  • joined 28 Feb'20 - 9 messages
try turning on the ignition and see if your ground appears?
maybe the ecm controls the ground? (seems unlikely though as you need ground full time to energize the machine when you turn the ignition on before starting it).
just thinking outside the box here ;o)
but on a more conventional thought...
my first thought is your ground cable to frame isn't making connection, it's open
  • Posted 2 Mar 2020 00:02
I put my meter on the positive cable and touched the frame...no continuity.
  • Posted 29 Feb 2020 16:29
  • By Ifixit
Definitely a dead short. Try taking battery wire off altrrnator and starter and see if voltage still drops.
  • Posted 29 Feb 2020 13:49
  • By James_Lott
Terberg YT222
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
RAEDER-VOGEL
Terberg YT222
USD1
