Optional Display
I have a Zapi 24 volt FC2086C in two Hysters, W40Z,s. both have four deep cycle 6volt batteries. Both charge up to over 26volts, but gauges will never show both green led,s for full charge. I have rung out wiring from battery to controller and to display. Has anyone else experienced this?
  • Posted 4 Jan 2020 01:08
  • By Torqued
  • joined 4 Jan'20 - 3 messages
  • New Jersey, United States
Thanks. Don't have the app for zapi. Maybe I should invest.
  • Posted 7 Jan 2020 00:36
  • By Torqued
These units have a zapi controller from what it looks like so:
there is no adjustable settings for voltage, it is already loaded into the configuration file in the firmware of the controller.
If you have a PC hookup you can get the factory config file and reload it into the controller and see if that fixes it.
otherwise the only thing you can change with the handset is drive parameters, or use the 'tester' function to monitor other operations for inputs and outputs. (you could go into that and see what the actual voltage is registering as and also check the percentage of the batterys). To see if they are registering correctly.
  • Posted 7 Jan 2020 00:31
  • Modified 7 Jan 2020 00:31 by poster
It is B218N32313N. I have a friend with a handset. Do you know if there is a changeable parameter?
  • Posted 6 Jan 2020 21:58
  • By Torqued
can you give me a serial number from one of them (or both)?
to make sure i get the right information on the unit, they made so many versions of this PJ/stacker.
  • Posted 4 Jan 2020 13:52
  • Modified 4 Jan 2020 13:56 by poster
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FD40T
GemOne
