CODE E-107 NO-TRAC,NO-LIFT
can, sombody give me a hand. i have a walkie pallet displaying this code. using handset coneccted directly to controller ,tells me it is watchdog or controller bad. want to make sure before replace it. code on display means the same failure componente? have no serv. manual
tanks.
  • Posted 6 Sep 2008 10:56
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
Code E-107, or No Power first thing to check. The wiring harness always breaks wires about 6 inches from the horn. If a horn wire breaks you will lose total power to the truck, have had a handful of these before, same area where the wires break each time.
  • Posted 5 May 2011 13:16
  • By Donnie
  • joined 5 May'11 - 2 messages
  • Louisiana, United States
hi, kurt, maybe a little delayed. Thanks for your assistance.
i still have the walkie pallet at shop, took the controller off the machine(1243c-4278),pluged the handset at bench test, notice that fld.min & fld.max parametres were= 0.2 both. it din't seem to me like a normal and change to fld.min=8 & fld.max=20, once instaleed back to machine,pluged again handset and turned it on. i relized that fld.curr. param. returned to 0.2 is it normal? RegardsĀ”
  • Posted 16 Oct 2008 12:41
  • By roldann
I am not sure but I think I had this a few times because of a bad wire harness. Drive the truck and see if you get the code when steering all the way left or right. If it does there is a service bulletin with a new and improved wire harness.
  • Posted 16 Sep 2008 13:14
  • By kurt_k
  • joined 16 Sep'08 - 3 messages
  • Wisconsin, United States
Mitsubishi FD200
SMV (Konecranes) 4531CC5
