Drive Motor not Engaging
I have a Mobile Industries RTS 33-118-A. The 24V battery charges to 100%. The hydraulic portion, lift, boom, extending, works fine. The drive motor only "clicks" when I press forward or reverse.
The control until has a yellow flashing light. I believe this is an indicator of a problem? I have cleaned all contacts/connections.
When I tilt the steering the solenoid clicks to energize, but when I press forward or reverse that narrow plate on the drive motor moves and makes a clicking sound, but no movement.
I am not an electric forklift expert by any means, but try to repair on my own.
I have photos of control unit and drive motor, but cannot post url.
Any ideas? Thank You
  • Posted 11 Dec 2019 04:41
  • By Walkingant
  • joined 11 Dec'19 - 1 message
  • Idaho, United States
i don't have any specific information on mobil equipment but i may can help.
If you can get the information off the controller data tag, brand, model number if any.
As for that flashing light on the controller?
if it is flashing a slow pulse every few seconds then that just indicates it is powered on and that slow pulse is normal.
Now if there is an error it should flash the error code with quicker pulses.
It would flash the first digit, then pause and flash the second digit etc.
most error codes are 2 digits for drive errors and 3 digits for hydraulic errors.
Lets say it has a drive system error and the code is E48, the light would flash four times in like 1 second succession, then pause for a couple seconds, then flash 8 times. It will continue to flash this code until it is resolved. If a hydraulic code just watch for a 3rd set of flashes.
Once it flashes all the active codes it will pause for a bit and then roll them out again starting with the first code you saw and so forth.
If you can get the information off the controller i have some info on most controllers and can help you figure out whats wrong.
  • Posted 11 Dec 2019 15:17
Briefs United States
