Right side axle will not go in
I recently did the brakes on my S30A which requires removing the axles. Both axles came out of the housing easy but the right axle will not go back in. It stops about an inch short. I'm guessing that there is a set of misaligned spindles in the 'pumpkin'. In a car all I need to do is rotate the opposite wheel or turn the drive shaft. But I've tried it all and can't get the axle in. Any ideas? Also, it looks like a previous owner cross threaded the axle spindle nut. I can clean up the axle with a thread file but the nut not fixable. Anyone have an idea of a part number or size for this? The thread checks out at 18 TPI.
11/5/19 - Turns out one of the lugs was slightly bent. straightened and the axle slide right in.
  • Posted 5 Oct 2019 06:25
  • Modified 6 Nov 2019 01:23 by poster
  • By kevin_kurland
  • joined 16 Aug'19 - 19 messages
  • New Hampshire, United States
Toyota 8FGU25
Flesherton, Ontario, Canada
UN Forklift FD30-35T
Hyster
