Jungheinrich etv114 battery 0%
Hi we have this jungheinrich reach truck which had stopped working after showing battery at 0%. We calibrate the bdi settings then works again. Recently went and changed the lisa display and 2 days later battery at 0% again. However the battery is actually 49v and under load drops to around 47 to 48v.
Can someone advise what they think could be causing this issue? Or which controller holds the bdi information.
Regards
  • Posted 4 Oct 2019 05:08
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hi.
Do you have a serial nr.? YOM?
Regards, Max
  • Posted 7 Oct 2019 19:22
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Thank's for helping. Contact d-b-a@mail.com
P i s s Work, gone fishing
Hi. We don't have another battery to v try. Settings are ok. Lisa display was changed. Battery seems to hold ok under load. I do still suspect battery now. Have asked to get battery people to come in and check battery.
Regards
  • Posted 6 Oct 2019 09:31
  • By elektrodrive
Hi , do you have the battery parameters 1 - 11 set correct?
Sure battery oke? Do you have try it with a different battery they are used in other truck? Lisa holds the BDI info
Regards
  • Posted 4 Oct 2019 16:46
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hawker Powersource, Inc.
