Code 425
I have a truck SP 3500 pulling up the code 425 when slightly movings in FF direction, checked the manual and ran everything it stated. POT is good. Voltage is as stated in manual. Last thing i did was the Handle Calibration.
any one else try or find something else other than this to fix this issue? much appreciated.
  • Posted 3 Jun 2019 19:23
  • By Mechanic_1217
  • joined 31 May'19 - 9 messages
Yes it was an issue only in one direction. I looked at the switch as u stated, and notice the throttle wasn't engaging the switch once it was being put in reverse. I noticed the throttle was a bit worn so I adjusted the the screw on the switch to engage better.
thank you for the response !
  • Posted 10 Jun 2019 15:50
  • By Mechanic_1217
From my experience with the Crown SP's we have found issues with the small directional switches. Look real close at the terminals on the switches for discoloration. Meaning high resistance. You can also run a resistance test on them with a good meter. As I understand you are having issues with on one direction correct ??
  • Posted 5 Jun 2019 04:27
  • By ScooterB
  • joined 5 Jun'19 - 4 messages
Sue Tomic Sue Tomic
Crown WP302020
UN Forklift FBRP15NQZ2
Crown WP302020
Sue Tomic Sue Tomic
