Still RX20-18 s/n 516213A65015
Hello everyone,
The battery indicator of the forklift shows 0% ,no traction and no hydraulics. The main contactor also doesnt closes. Tried a second battery but the result is same and both batteries are in perfect condition. I did some checks on start up cabling of SU,MCU etc (48V ,24V and 12 V suplying) and seems all good except the terminals XS4 and XS5 has only <20 Volts. Can any of converters cause this problem? is there any way to check them ? its not easy to disconnect them without dismounting the fuse box as the power is connected via metal plates and not cables. Any ideas what else can cause the trouble?
Thanks
  • Posted 21 May 2019 02:25
  • By Bavaros
  • joined 16 Jun'12 - 21 messages
  • xanthi, Greece
The contractor is ok,there is no supply cabling is ok
  • Posted 23 May 2019 03:45
  • By Bavaros
  • xanthi, Greece
check contactor supply or change it
  • Posted 22 May 2019 09:12
  • By prepaito_d
  • joined 17 Dec'17 - 177 messages
  • iztapalapa, Mexico
Maxlion FB35LI
Toyota 8FG25
