Yale forklift GLC050vx will not travel forward but backs up
Fault code# 524225-1 Will back up but not forward. put it into reverse once then forward and it went forward a little bit and then would not go both ways. Turn it off and started again and then only backed up. Any advise would be appreciated. Also would want to buy repair manual. Toro
  • Posted 10 May 2019 06:42
  • By toro
  • joined 10 May'19 - 15 messages
  • British Columbia, Canada
THANKS FOR YOUR REPLY. WHAT SHOULD THESE DIFFERENT PRESSURES BE? I ASSUME TESTING PORT IS ON TOP OF TRANSMISSION(WERE)? OIL ON LOW SIDE (TYPE)? SENSOR SUPPLY( LOCATION) WHAT SHOULD IT READ? (SENSOR FAILURE MEANING B)? D MEANING TRANSMISSION CLUTCH PLATES NEED TO BE REPLACED? IS IT POSSIBLETO GET SCHEMATIC OR REPAIR MANUAL. THANKS AGAIN.
  • Posted 11 May 2019 12:30
  • By toro
DTC 524223-1 - XMSN Reverse Pressure Less Than Commanded
DTC 524224-1 - XMSN Forward 2 Pressure Less Than Commanded
DTC 524225-1 - XMSN Forward 1 Pressure Less Than Commanded
DTC 524229-1 - REV 1 Valve Pressure Auto Low, Calibration Failure
DTC 524270-1 - FWD 2 Valve Pressure Auto Low, Calibration Failure
DTC 524276-1 - FWD 1 Valve Pressure Auto Low, Calibration Failure
POSSIBLE CAUSE
A. LOW TRANSMISSION OIL LEVEL
B. SENSOR SUPPLY OPEN CIRCUIT
C. SENSOR FAILURE
D. FUNCTIONAL FAILURE - MECHANICAL
  • Posted 11 May 2019 06:31
  • By BREWSKI
Mitsubishi FGE35AT
Ncn 110TH
Ncn 110TH 2015
RAEDER-VOGEL
Mitsubishi FGE35AT
Ncn 110TH
Ncn 110TH 2015
Michel Denis Michel Denis
