Hopper will not go up, no engine high speed.
I have a Tennant M30 sweeper. The problem I am having is when you try to raise the hopper the engine does not go into high speed. The engine stalls when hopper switch is pressed to go up. If I hit the engine high speed button by it self the engine does the same thing. It stalls and has no engine high speed. When i go to self test mode it shows P2-26. Has anybody had this issue before and can recommend anything?
  • Posted 17 Apr 2019 23:45
  • By Richy
  • joined 17 Apr'19 - 1 message
The P2-26 refers to the connector pin on the operator control board. P2-26 is for the FaST side brush valve (solenoid valve to turn on the FaST soap pack to the side brush). From what you've described, the P2-26 code that comes up after you run the self-test is indicating a problem with that particular function. This is a separate issue from the engine stalling.
On that note, the engine stalling could be an issue with the connection to the the ECM or a faulty ECM. Get a wire schematic for the ECM and M30 to help guide you through the many wires to the ECM. Best of luck!
  • Posted 8 Apr 2021 23:22
  • By RCScrubTech73
  • joined 8 Apr'21 - 1 message
  • Michigan, United States
Airman ENCL045
Nagano NUZ090D
Sue Tomic Sue Tomic
VETTER Forks, Inc.
Sue Tomic Sue Tomic
