mast slow to go down
I am having an issue with my Hundai 30D-7E. The mast is very slow to lower in all stages. All other hydraulic functions, including mast raising, function as normal. I have disasembled the valves and solenoids and all o-rings look good and did not see any debris. Any helps on this would be much appreciated.
Thanks,
Maitland
  • Posted 13 Feb 2019 10:03
  • By maitland_u
  • joined 13 Feb'19 - 1 message
the mast should have a safety valve in the base of the rod of the freelift cylinder. This safety valve may be bad or may have come apart. I have seen this happen alot in many brands and models of trucks. I would take out the freelift rod/piston and check this.
There is also a velocity fuse or safety flow control valve in the supply line either at the base of one of the primary cylinders in a special adapter fitting or a valve in a manifold block mounted on the rear side of the mast where the main lines go to the cylinders, this controls decent speed in case a line ruptures to keep it from dropping too fast, this is not a common scenario but is possible and should be considered looking at if the safety valve is not found to be an issue.
  • Posted 13 Feb 2019 22:04
  • Modified 13 Feb 2019 22:05 by poster
