hyundai 20B-9
code
M4F incorrect start
PDF SBR S/W open
  • Posted 28 Dec 2018 18:01
  • By dato_georgia
  • joined 15 Aug'18 - 34 messages
  • Georgia
Showing items 1 - 17 of 17 results.
P=pump
4F is incorrect start.
It could be that the calibration from p-lift sensor (or other analog signals)is off, therefore when starting up the machine's pump controller will give a start-up error since it's out the "safe" range.
  • Posted 7 Oct 2022 19:22
  • By Speedfreak
  • joined 24 May'18 - 103 messages
  • Niederlande, Netherlands
Hi,
I need the manual also as I'm facing the error P4F, Can you please share with me. Will be thankful to you.
  • Posted 10 Sep 2022 18:52
  • By Syed
  • joined 14 May'15 - 196 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
Added
  • Posted 29 Jan 2020 23:03
  • By hyster123
  • joined 23 Mar'19 - 9 messages
dave
All potentiometers can be calibrated in VASS settings menu. e-mail?
  • Posted 29 Jan 2020 18:26
  • By Speedfreak
Hoist'er123, Please put your email in profile.
  • Posted 29 Jan 2020 13:17
  • Modified 29 Jan 2020 13:20 by poster
  • By EasiTek
Does anyone know factory set service level password? Can accelerator pedal be calibrated using display?
  • Posted 11 Jan 2020 05:09
  • By hyster123
dave
thank you very much.
ok i will check
  • Posted 29 Oct 2019 23:18
  • By Zouhair_Bekk
  • joined 25 Oct'19 - 4 messages
  • Morocco
m4f is an incorrect start, either driving direction is not in neutral, or accelerator pedal and or brake pedal is not in rest-position before (seat switch) and keyswitch are activated.
If the truck is active, also the seat switch must be closed before accelerator and/or direction switch is closed, if not> truck will give incorrect start (as the name implies).
Same goes for when the truck is in SRO Static Return Off, all inputs must be neutral.
  • Posted 29 Oct 2019 21:23
  • By Speedfreak
Good evening please the problem
what is m4f what is the solution
Thank you
  • Posted 28 Oct 2019 08:27
  • By Zouhair_Bekk
  • Morocco
Bonsoir s'il vous plait le probleme
que vous m4f c'est quoi la solution
Merci
  • Posted 26 Oct 2019 00:21
  • Modified 26 Oct 2019 08:41 by poster
  • By Zouhair_Bekk
  • Morocco
Thanks for your attention Speedfreak
  • Posted 8 Jan 2019 19:39
  • By dato_georgia
  • Georgia
mail send, good luck!
  • Posted 7 Jan 2019 17:40
  • By Speedfreak
datobasheleishvili1@
gmail
  • Posted 4 Jan 2019 20:55
  • By dato_georgia
  • Georgia
email adress?
  • Posted 4 Jan 2019 20:48
  • By Speedfreak
PDF SBR e12 and e4 are nc.
but The code is still on the dyspley.
and MF4
How to make sure that the Accelerator is damaged.
Accelerator modell MTF13 comesys
  • Posted 4 Jan 2019 20:18
  • By dato_georgia
  • Georgia
PDF SBR switch is related to the battery-door switch.
NC switch on right side of machine on battery-door.
To prevent driving when battery-door is openend.
Very often the wiring of this switch is getting between door and chassis, resulting in broken wiring.
For testing purpose, just remove switch, connect the 2 wires so master will see this as a NC contact.
If unsuccesfull, wiring is broken.
Connection on pumpcontroller E12, wire 68 switches to E4 common wire 222 (A trough E)
Good luck!
  • Posted 28 Dec 2018 19:19
  • By Speedfreak
MF4= wrong traction request sequence
M=master
4F = incorrect start.
After switching on keyswitch either driving direction is not in neutral or acceleration pedal is not in zero position.
Calibrate acceleration pedal if problem exists.
  • Posted 28 Dec 2018 19:10
  • By Speedfreak
Manitou M50-4
Toyota 4FD240
