Code 8L
If you are having an intermittent code 8L make sure to check the wires and the connection where the brake assembly plugs into the units wire harness at the top of the drive motor. The plastic ties are set very tight from the factory and either cut in to the wires or plug the wire from the solderless pin.
  • Posted 7 Dec 2018 06:51
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Recently had the code 8L but it was not for as broken wire. The brake coil is supposed to OHM out at 9 to 10 OHM's but I had 0. Installed new brake assembly to solve the issue.
  • Posted 23 Apr 2019 05:50
  • By tyler_d
Nice. Thanks for the advice.
  • Posted 12 Dec 2018 18:11
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Manitou M50-4
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Combilift Ltd
Oxford Ct, United States
Esie Cortez Esie Cortez
