Contacts won't engage
The fork lift will not move or lift. It worked the previous day. The battery is fully charged. The battery indicator shows no voltage though. Horn works, lights work. Beeper works when put into reverse. Manually depressing the contact, the lift works. Voltage drop is minimal. The model/serial# is Yale ERCO30ACN (2004). This is an electric forklift. Any help is much appreciated!
  • Posted 3 Nov 2018 21:04
  • By Rabbitt
  • joined 14 Jan'15 - 14 messages
Never too old to learn
Canbus= Controller Area Network (nervous system enabling communication between all parts of the body). Always learning something new, Thanks!!!
  • Posted 29 Nov 2018 23:43
  • By Rabbitt
its all about canbus
  • Posted 29 Nov 2018 23:23
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
Solved! The Battery indicator was bad. Luckily I had another identical Fork lift to swap out the part. Who knew the battery indicator would prevent the forklift from working. Must be in series.
Hope this can help someone in the future.
  • Posted 4 Nov 2018 01:14
  • By Rabbitt
Mitsubishi Logisnext FD25T5M
Terberg YT220
ROYPOW
