0341 error code
one of our toyota fork lift 8FBMK16T model showing 0341 error code starting long time ago we have tried our best to get the problem but up know we cant found it
-both traction , material logic & MCB controllers are new(ok)
-wheel speeed sensor , motor & both contactor good
-we have done parameter and calibiration
kindly help as
  • Posted 1 Nov 2018 23:42
  • By fitsumamare_m
  • joined 1 Nov'18 - 1 message
  • Ethiopia
Hello Sir
This can help you to solve the problem.
And look at the software in the display are very important!
0341
IQ MISMATCHED (left traction logic unit - master microcontroller)
Circumstances of error detection
The left traction logic unit (AU2) has detected a problem with the configuration of parameters stored in memory.
Actions:
? Run a key reset and check the correct value of the drive parameters on the display
? Eseguire un reset dell'unità logica trazione sinistra utilizzando la funzione TO DEFAULT SET
? Update the software version of the MASTER and SLAVE microcontroller on the left traction logic unit
? The insulation of the left drive motor (see paragraph INSULATION CHECK PROCEDURE):
If the measured value is less than 1MO replace the motor
Self-diagnostic
? Invert the right traction logic unit and the left traction logic unit
? Reset both logics (MENUETC - TO DEFAULT SET) and repeat the potentiometers calibrations:
? If the fault code changes from 0341 to 0241, replace the traction logic unit originally on the left
? If the fault code remains 0341, the cause of the fault is outside the left traction logic unit
Regards
John.
  • Posted 2 Jan 2020 20:49
  • By TraigoGen
  • joined 2 Jan'20 - 12 messages
  • Netherlands
Terberg RT403
Mitsubishi Logisnext FD25T5M
Terberg RT403
Sue Tomic Sue Tomic
