Hyster E35XM
Hi all! I need help on a Hyster 35XM, it has an Ev100 sysytem and has no reverse. Showing a code 06 - accelerator depressed and no direction selected...any clue on how to get this puppy going?
thanks,
helen
  • Posted 8 Jul 2008 00:46
  • By helen_b
  • joined 8 Jul'08 - 3 messages
Helen, you haven't cleared up if it's stick or pedal switched?
I'd forget the error code first of all. Fault 06 is what your creating by pressing down on your accelerator pedal while the truck is in neutral, I can't see it being the accelerator pot as you say you've only lost drive in one direction - correct?
You say your "switches" don't look burnt? Are you talking about your contactors here or are you referring to your directional selection switches? How can you say your switches don't look burnt? They are tiny encased micro switches, you'd never see burning on them unless you smashed them apart somehow.
It's a safe bet what Kev's getting at is right, check your reverse micro switch - not the reverse contactor tips which I think is what your looking at?
  • Posted 8 Jul 2008 04:10
  • By FLTdotCOdotUK
  • joined 28 Jun'08 - 21 messages
  • Tyne & Wear, United Kingdom
is it monotrol or lever control. the pot on the footpedal could be out of adjustment. try slackening off the pot and turning anticlockwise a bit at a time retighten and try. if this doesn,t work test the pot.
  • Posted 8 Jul 2008 03:15
  • Modified 8 Jul 2008 03:34 by poster
  • By kevin_k
switches are fine and nothing looks burnt up, i still have the code 06 though and it has no reverse...any thoughts?
thanks,
mark
  • Posted 8 Jul 2008 02:57
  • By helen_b
check your direction switches. they are either stuck in or broken
  • Posted 8 Jul 2008 02:25
  • By kevin_k
Ncn 85TH
Ncn 85TH 2014
Maxlion FB25LI
Briefs United States
F. Uchiyama
