ERROR CODE 200-31
We have a Hyster h90ft d005v05617r w/Kubota diesel , has error code 2000-31 , does not start , any suggestions ?
  • Posted 25 Sep 2018 05:53
  • By sergio_g
  • joined 25 Sep'18 - 8 messages
Anyone have any luck sorting this? I have the same problem with my H8.0Ft6 with ku ota v3800t diesel engine
  • Posted 9 Nov 2024 08:03
  • By EHUKLTD
  • joined 9 Nov'24 - 2 messages
  • United Kingdom
did you ever figure out what was causing this code?
  • Posted 6 Dec 2023 23:14
  • By brando
  • joined 3 Jun'23 - 3 messages
brando
Hi mate, just wondering if you had any luck resolving this issue? I've got the same model with the same fault. CAN lines/termination resistors are all ok. I'm suspicious of the engine ECU due to a few suspect readings it's giving.
  • Posted 16 Jun 2020 21:38
  • By TomK95
  • joined 16 Jun'20 - 1 message
  • Gloucestershire, United Kingdom
please check fuses ign 1,2,3 in the PDM or fuse box this is located under the floor plate. there is a diagnostic port on the steering colum with mulitmeter on resistance scale check between 3 wires you should get about 60 ohms if you get 120 ohms you have a problem
  • Posted 28 Sep 2018 05:54
  • Modified 28 Sep 2018 05:55 by poster
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
CAN = Controller Area Network
CAN CONNECTED is the status of the CAN or that a network device/node is connected or not connected.
Generally this would be accompanied with a message like CAN CONNECTED HI or CAN CONNECTED LOW (something like this)
  • Posted 25 Sep 2018 23:12
hi I am tech working on this unit what is CAN CONNECTED ?
  • Posted 25 Sep 2018 07:07
  • By sergio_g
DTC 2000-31 - CAN Tx Failure
DTC 2000-31 - CAN Rx Failure
A. TERMINATION RESISTOR(S) OPEN CIRCUIT
B. OPEN/INTERMITTENT CIRCUIT ON CAN HI, CAN LO
C. CAN HI AND CAN LO SHORTED TOGETHER
D. OPEN CIRCUIT ON POWER/GROUND TO CAN CONNECTED DEVICES
E. STG ON CAN HI
F. STS/STB ON CAN LO
G. CAN CONNECTED DEVICE FAILURE
  • Posted 25 Sep 2018 06:25
  • By BREWSKI
Kai von Berg Kai von Berg
