Steering issue
We have a unit here that has everyone stumped. Unit will not steer nor drive. Premium display shows SteerContact. The unit has (2) Curtis 1243C controllers and one 1310 MCU. The steer contactor ohm's out correctly and will close manually when disconnected from the system. All the wiring for the on-demand steering has been checked. The steer motor with the controller built in and the steer sensor has been replaced. None of the Curtis controllers shows a fault code when checked via a handset. If the positive wire to the traction contactor coil is unplugged, the steer motor goes into idle mode and operates correctly. Everyone here is thrown their hands up and we will not throw parts at it. Any help would be greatly appreciated.
  • Posted 8 Aug 2018 02:33
  • By SFMH
  • joined 8 Aug'18 - 4 messages
post a full serial number of this truck please
  • Posted 10 Aug 2018 13:24
Do a defaults and program the truck per service manual set up instructions. This text message will appear when a controller has been installed on a truck built before july 2007 and then reinstalled on a truck built after july 2007.
  • Posted 10 Aug 2018 11:28
  • By glock01
  • joined 26 Apr'09 - 19 messages
  • Idaho, United States
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
Manitou M50-4
Mitsubishi FGE35AT
