Steering is hard
Serial number K160N03473L
Any ideas on why this feels like it has manual steering? The lift has hydraulic steering and all of my other hydraulic functions operate well. Any ideas on what to check would be greatly appreciated.
  • Posted 23 May 2018 08:07
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
Priority valve is in the inlet section of the main hydraulic control valve.
  • Posted 30 May 2018 04:17
  • Modified 30 May 2018 04:17 by poster
  • By BREWSKI
there should be a sensor on the column to speed the motor up whgen you turn unplugging sensor should give you full speed.
  • Posted 30 May 2018 03:44
  • Modified 30 May 2018 03:52 by poster
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
I am getting zero pressure out of it. It is also difficult to steer when i put it up in the air. Is the priority valve part of the steering control unit?
  • Posted 30 May 2018 02:07
  • By lvscr
First thing is a pressure check. Your problem could be in the priority valve or in the steering control unit. It could also be a mechanical problem in the steer trunnion.
  • Posted 23 May 2018 22:37
  • By BREWSKI
Sue Tomic Sue Tomic
