Rear Lift Cylinders Drifting
Lifts OK but when in 2nd or 3rd stage (outboard lift cyls.) the mast will drift down. FSV 3-Stage Mast
Overhauled both rear outboard lift cylinders & still doing same thing.
Anyone have an idea where to check next.
  • Posted 17 Apr 2018 04:36
  • By JAKE2
  • joined 7 Jul'17 - 36 messages
We O/H both the 2-rear & primary lift cylinders.
When we lift the mast up it stays in position but when we lower it down it will drift. This happens in any stage...
  • Posted 24 Apr 2018 23:11
  • By JAKE2
there are check valves in the bottom of the cylinders to verify remove cap and check for fluid in the top of the cylinder as this has lower packing as well as packing in the cap
assuming its not the primary cylinder if your mast is staging correctly it is ok
  • Posted 23 Apr 2018 06:21
  • By forkguy
  • joined 25 Jul'17 - 28 messages
We normally instal a hyd switch/gate/ball valve lock off onto the hyd pressure feed line - with the valve open raise mast - then with hyd levers in neutral. close the valve - if it drifts down its the seals in the cylinder. if it stays up its normally a hyd control valve( Spool)
Safety tip -- relieve all hyd pressure before installing check valve - lower mast to ground - these machines will bite you....or kill you....
  • Posted 17 Apr 2018 23:21
  • By Prentice
Taylor T520M
Taylor TE650S
Taylor T520M
Taylor TE650S
