Glp080vxnase090. Unit goes Into engine shutdown in 30 seconds. After key on and starter jumped Code is for rear work lights only. F7 fuse dead and relays for start have been replaced. No output power from this relay to power f7. Unit can be jump started on starter and starts fine this way. Relay clicks on but won't power f7. Pdm bad or ?
if you have old software in the truck a light being out will shut it down. fix whatever is wrong and it still wont run, wants the laptop to plug in. I don't know what software version they took that crap off maybe someone else does and you can check if that's what's going on.
had this happen to me ,did pm and disconnected the temp senor wire off with air plug n play...maybe wire disconnected ? shutdown is for safety..chq seat sw,parking brake out o f adjustment or other add ons...my Canadian nickle worth..later !
