Steam from exhaust & water in engine breather
I think I know what the problem is after having the head pressure tested I am assuming there must be a crack in the block below the piston. Before purchasing a new block I just wondered whether anyone else has had a "steam train Linde" or any engine with similar symptoms?
Thanks
Gaza
  • Posted 8 Nov 2017 20:36
  • By Gaza
  • joined 22 Jul'10 - 11 messages
  • Australia
Had a "steam train Toyota". a mid 80's, 3k lb model, toyota 5R engine. Would steam up and burn oil after getting up to operating temperature. The root cause was a failed 35 year old head gasket. Pulled it apart, installed new head gasket, fired it up, flushed engine oil system twice and she has been purring like a kitten ever since.
  • Posted 11 Nov 2017 15:28
  • By Jetty
  • joined 12 Mar'17 - 44 messages
www.BacliffRV.com/Toyota_Forklift
What machine?
Serial number?
Diesel or lpg?
  • Posted 11 Nov 2017 15:20
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Airman ENCL045
Ncn 110TH
Ncn 110TH 2015
