BT REFLEX RRE 160 error code 3:328
Hi Everyone,
Does anybody know what means error code 3:328 on BT REFLEX RRE 160?
  • Posted 9 Aug 2017 18:56
  • By bartosz_g
  • joined 26 Jul'13 - 8 messages
  • Grudziądz, Poland
3:328 = Short circuit in the ACT, the drive motor or the motor cables.
The truck is braked by the motor brake until it stops.
Check
1.That the motor cables are undamaged and there is no short circuit between them or with B-.
2.The motor windings' resistance to the motor yoke, there should be no relationship.
3.Test using a new motor controller. If the error persists, the fault is probably an internal motor problem. Replace the motor and refit the old controller.
Both the frequency convertor boxes under the pedals are the same, you can swop there positions & see if the fault then moves to the hydraulic pump motor.
  • Posted 11 Aug 2017 02:36
  • Modified 11 Aug 2017 02:38 by poster
  • By Forkingabout
  • england, United Kingdom
Briefs United States
Hyster
