The lifts hydrualic pump is not working...
the forks are tilted all the way back and pump is bad. is there a way to tilt the forks forward to work on the pump/motor?
  • Posted 28 Nov 2020 13:59
  • By werthy1
  • joined 27 Feb'16 - 26 messages
Thanks again. took a couple of pig pads to soak up mess....
  • Posted 1 Dec 2020 15:19
  • By werthy1
Glad that worked. I can imagine the mess it made!
  • Posted 1 Dec 2020 10:21
  • Modified 1 Dec 2020 10:22 by poster
  • By Triggs
I unhooked the two lines going to manifold and made a mess but use another lift to pull mast forward to get the room needed to remove motor/pump assembly.
  • Posted 1 Dec 2020 08:04
  • By werthy1
ok thanks. I will try that.
  • Posted 28 Nov 2020 15:04
  • By werthy1
You could loosen the tilt hose fittings and manually pull the mast forward
  • Posted 28 Nov 2020 14:21
  • By Triggs
Bolzoni SpA (Group HQ)
St. Louis, MO, United States
Evansville, IN, United States
Uxbridge, Canada
Daleville, IN, United States
