Telescopic cylinder removal
Hey guys. I'm about to remove a cylinder from this truck. Looks a little intimidating, it's the only cylinder that lifts all mast rails. Any tips on how to to chain/block this to get started? Looks like it's bolted in several different places with a snap ring on top. I'm assuming carriage has to be completely removed?
All info appreciated!
  • Posted 3 Mar 2025 15:13
  • By Michael_Brown
  • joined 17 Jan'25 - 14 messages
45 years as lift tech and I've seen a lot of accidents with lifts.glad you got it done and safely I retired from a Clark dealer so I've done several of those in the field and also resealed
Them. again glad it's done and all is well !
  • Posted 24 May 2025 06:27
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
Yup I got this all done and completed. I am an independent forklift tech. I took the cylinder to a hydraulic shop for the rebuild. I've never removed a single telescopic cylinder like this before.
This project takes a few blocks and chains to be safe. You really have to think about each step before you remove something else. There are a couple YouTube videos of this job as well. I luckily had a over head crane to remove the heavy cylinder once I got it all disconnected.
  • Posted 24 May 2025 05:36
  • By Michael_Brown
This is one of the most dangerous actions on a lift truck I know several people that have lost fingers , hands , arms and their life doing this
If you are uncertain about this repair get professional help if determined to repair ,chain with a good quality heavy chain then double it for security those are telescopic cyls
Not hard to disconnect but very heavy and bulky you will need another lift or another person to remove safety good luck and be safe
Remember no such thing as too many chains
As far as blocks be sure they are oak or other dense wood if you use them
  • Posted 24 May 2025 04:44
  • By John_Bradley
Jb69
Yes the carriage has to come out. Put the forks and carriage on top of a pallet. Using a C clamp, tighten one of the forks to the pallet.Pull the cotter pins for the carriage chains, take loose ,lay over the carriage and Raise the mast up to drop carriage out of the bottom and drive lift in reverse to free the carriage.install a 2 foot 4x4 block across the top of mast and 2nd rail. Let the mast down into the blocks of wood. Unbolt the four bolts in the back of rail, I believe it was a 12 point 5/8 socket and remove the snap ring on top. There will be two 5/16 bolts and nuts on the bottom rod mount and of course take the supply hydraulic hose off.
  • Posted 24 May 2025 03:08
  • By Flaj76
  • joined 8 Jul'20 - 5 messages
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
