Yale GDP080LJNPBE097:
techtronix 100 transmission working pressure
what is the working pressure of the techtronix 100 transmission
  • Posted 23 Jan 2014 04:34
  • Discussion started by keith_n
all rebuilt
the friction disks where burnt smooth
all is well thanks
  • Posted 6 Jun 2014 01:04
  • Reply by keith_n
Kieth,
All techtronics pressure problems should start with a trans valve calibration. Don't pull the trans without a full set of pressures.
JJ
  • Posted 6 Jun 2014 00:02
  • Reply by jim_j
all indcations are the clutch pack i'm starting to pull the engine / trans
I'm still waiting on my service manual can the clutch packs be changed by removing the back cover and not removing the transmission from the engine? it would save a lot of work
  • Posted 4 Feb 2014 04:29
  • Reply by keith_n
Keith, I understand you have changed the TSP sensors , have you checked the supply voltage from the vsm to the sensors you can do this by back probing the connectors your looking for 5 v or there abouts. Reconnect the connectors to the sensors and back probe the sensor connector again measure the voltage across the sensor wire to the negative, if it's greater than 0.5v is yes then the sensor is faulty. If the answer is no then cause could be mechanical.
  • Posted 25 Jan 2014 04:24
  • Reply by NER045
fault code 524225-1 my fear is clutch pack also is there a trouble shooting section in the service manual i'm guessing the engine and trans come out together
  • Posted 24 Jan 2014 23:11
  • Reply by keith_n
Keith, what is the code displayed, as more info may be supplied to point you in the right direction to solve problem.
  • Posted 24 Jan 2014 19:38
  • Reply by NER045
Kieth, I think you will have to do some pressure tests, from one of your previous post I understand that the truck will travel in rev direction, if that is so you should be able to see a drop in selected pressure when you change direction witch may indicate a failure in the clutch pack. I will consult my notes further and let you know if I have any other info.
  • Posted 24 Jan 2014 08:20
  • Reply by NER045
thanks thats a start I ordered my manual it should be in soon
so far I have changed my oil and filter cleaned the sump screen and i still get a low pressure code and shut down any tips
  • Posted 24 Jan 2014 06:58
  • Reply by keith_n
Hi keith, transmission pressures are -
Charge pump relief valve is set at 200 lbs ins
Pressure in the trans control valve for clutch pack is 160lbs ins and torque converter 112 lbs ins.
Hope this is sufficient info.
  • Posted 24 Jan 2014 06:11
  • Reply by NER045
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
edition #1235 - 19 June 2025
