TCM -FG20N5T -A31S54469 -Engine has no power H20
Hello, My customer complains of no power when lifting and/or driving. When unit is in neutral, engine will rev up to 2500 - 3000 RPM - exhaust sounds very noisy but has no leaks around muffler?????No Smoke engine purrrs like a kitten, I have changed ignition system, and rebuilt CA55 Carburetor. I was thinking of timing chain or compression test, Governor assembly. Any ideas so i can sleep at night. Customer is about a 3 hour drive. need as much information as possible.
  • Posted 20 Feb 2009 23:56
  • Discussion started by Prentice
I should have known better. Compression test confermed that #1-2 cylinders low----Head gasket----stick to the K.I.S.S method
  • Posted 26 Feb 2009 00:25
  • Reply by Prentice
Thanks guys. just got the unit in our shop i will let you know what i find
  • Posted 25 Feb 2009 01:43
  • Reply by Prentice
If it has one of those vacuum governors mounted under the carb. check to make sure the spring pulling the throttle plate open is not broken.
  • Posted 22 Feb 2009 04:10
  • Reply by mrfixit
"When unit is in neutral, engine will rev up to 2500 - 3000 RPM"
is this a truck with a torque converter transmission? this sounds to me like a cracked impeller in the torque converter. what happens on a ramp? does it drag the engine speed right down?
  • Posted 22 Feb 2009 00:20
  • Reply by edward_t
prentice check distributor weights under rotor for siezed parts timing chains do not cause many problems on h20 engine you say exhaust noisy i have seen them collapse inside causing a restriction try removing ex pipe manifold good luck
  • Posted 21 Feb 2009 23:31
  • Reply by towmotor
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
