Switches direction when controller released
I have a Easi R30TT S/N: ET-D-00-08776. Going forward or reverse, when you go to neutral the unit will start going in the opposite direction. Forward is now getting jerky at low speed. I thought directional controller, but it does it both ways. and that doesn't make sense. Any ideas would be greatly appreciated
  • Posted 30 Sep 2015 21:51
  • By mardabas
  • joined 25 Jan'12 - 18 messages
  • Michigan, United States
Same problem , same solution , Thanks a lot!!
  • Posted 22 Dec 2017 08:58
  • By gabrielrc
  • joined 6 Dec'17 - 3 messages
  • Quebec, Canada
Thanks, it was the encoder gear on the motor.
  • Posted 15 Oct 2015 05:53
  • By mardabas
I assume you checked the set screw holding the throttle shaft of the control handle?. next is the pot itself. A tab holds it in place. If loose, it will do what you describe, however, you might not pass self test on start up as the pot is out of range.
Next is the encoder belt (on top of drive motor). Check the gear wheels that drive the belt. If loose, they give false readings
  • Posted 2 Oct 2015 21:09
  • By EasiTek
Taylor TX330S
USD159,500
Airman ENCL045
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
Taylor TX330S
USD159,500
Airman ENCL045
Alogotransiphobia is the fear of being caught on public transport without a book to read.
Taylor TX330S
USD159,500
Airman ENCL045
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
