Surging when driving fast or slow in forward or reverse
I have a Linde H30D H2X393S06051 with a surging problem. When trying to drive at a steady speed (fast or slow, forward or reverse) the lift will surge as if you are quickly pressing down and letting up on the accelerator pedal. With the laptop computer hooked up I am not seeing any variation coming from the electronics feeding the HPV. I hooked a gauge up to the F port on the filter and I have about 20 Bar of charge oil pressure at idle. When driving the charge pressure fluctuates. It will drop down to about 12 Bar this is when the lift slows down. The pressure will go back up to 20 Bar and the lift will then speed up. Thanks for any suggestions as to why the charge pressure is fluctuating.
  • Posted 28 Feb 2013 06:23
  • By IFD45
  • joined 28 Feb'13 - 31 messages
  • Wisconsin, United States
Both of the previous posts are correct, here's some further info: between 2006 & 2007 the forward/reverse solenoids were changed from a square unit mounted with four screws to a round unit that screws in. The later round units almost never gave trouble compared to the earlier square units.
Additionally, there is a throttle pedal position sensor that can give trouble and cause the same issue. It's under the floor plate and attached to the forward/reverse pedal assy.
Edit to ddrr's post: if it's the pedal position sensor or the ring gear worn, occasionally it will throw an error code, although more often will not. Also the ring gears wear in three places, and can be viewed at the top of the engine next to the hydrostatic pump, or through a hole in the bottom of the bell housing on the engine side (there's a grommet to remove) accessible if the floor plate/sump cover plate is removed.
  • Posted 11 Mar 2022 11:55
  • Modified 11 Mar 2022 11:59 by poster
  • By CharlesM
  • joined 4 May'17 - 13 messages
  • Victoria, Australia
Any help appreciated!
Look at your ring gear teeth. Had this problem fool us around. Each time the ring defect area will pass in front on the speed sensor it will cause the pressure drop and rise. The problem is much more worse at creep speed than hi speed and is is identically the same whatever the direction. Let me know if I'm right.
  • Posted 14 Apr 2014 02:56
  • By Dwaive
  • joined 7 Aug'09 - 33 messages
  • Quebec, Canada
Dwaive@hotmail
Montreal, Canada
3 solenoids on transmission basically below air filter.
Middle one is brake release, outside are fwd/rev,
If one direction is worse than other, try switching around the core/ valve. Replace them if travel bad both directions.
It's doesn't show up on diagnostics
  • Posted 12 Mar 2013 13:56
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Taylor TX330S
USD159,500
