Surging when accelerating
Have a Clark LP 3000# forklift, ser #CMC158L-1091 (6853KF). (attachments SS10105 50T)
Problem started suddenly, Unit will start and idle fine, but when trying to accelerate it will stall if pedal is pushed too fast, or can slightly accelerate and use it, or if accelerator is just right it will surge in RPM's repeatedly. I understand it has a Mitsubishi 4 cylinder engine with an Impco Model 100 carburetor.
Put a new diaphragm in the carb, new rebuild kit in the regulator and changed fuel filter. Maybe it helped slightly?
Looking for new ideas?
  • Posted 11 Oct 2022 08:56
  • By Cecil
  • joined 11 Oct'22 - 4 messages
  • Michigan, United States
Cecil
Have the governor removed, can see the butterfly valve. It is in the open position by default and can feel spring tension on it when pushing it closed. Can blow in the vac tube which tries to close it, but not hard enough to close it all the way. Removed the triangle plate to view the plunger that operates valve. Plunger conceals spring. Think it needs adjustment? and how do I access it?
Update: Found adjustment spring, phillips screw was loose on pivot and had moved slightly, adjusted screw and tighted, then put a little more tension on the spring. Problem Solved!!! Thank you for your help!
  • Posted 13 Oct 2022 08:57
  • Modified 13 Oct 2022 10:12 by poster
  • By Cecil
Cecil
When l said check governor l did not mean spring in carb l meant under carb there is a governor with a butterfly plate that controls the rpm so the engine can't over rev.it is set at around 2600rpm unless it is a computer truck it has a spring inside that might be broke or need adjusting. The hose I think you are talking about goes from the govern to the air cleaner it is open to the air. The hose is approx 5/16 what you are doing is holding open the plate so the truck runs with your finger on the hose
  • Posted 13 Oct 2022 04:31
  • By Scott_
Scott
Yes after replacing the Imco regulator and new diaphragm/spring in the carb, it did the same thing.
With hose from air cleaner to valve cover disconnected, I plugged the end that attaches to air cleaner with my finger and it was able to build vacuum on my finger and on the small vacuum hose that attaches to the top of the carb. Can now accelerate just fine until I remove my finger? Seems like it needs a pcv valve in the line to build vacuum but there isn't one there??
  • Posted 12 Oct 2022 22:31
  • By Cecil
Cecil
I would check govern under carb sounds like spring might be broke or need adjusting if you say engine is surging up and down
  • Posted 12 Oct 2022 14:04
  • By Scott_
Scott
Maxlion MTF30-45-2WD
Terberg YT222
Terberg YT222
