steering fault
this is a powered pallet truck,year 2005 with power steering,the steering is very juddery in the upright position and when operating.Any help would be appreciated.
  • Posted 10 Jul 2010 05:35
  • By bruce_k
  • joined 10 Mar'08 - 15 messages
  • devon, United Kingdom
Hi Titus,
i also have a yale mp20x with a faulty accelerator, yale have told me that the module will need programming when a new accelerator is fitted, please tell me if this is correct, if so what do i need to communicate with the nacco module.
Thanks.
Gary.
  • Posted 29 Oct 2011 00:15
  • By gary_f
  • joined 8 Aug'09 - 57 messages
  • Malaga, Spain
Hi Titus,Machine is now sorted your assistance was very much appreciated.
  • Posted 8 Aug 2010 21:10
  • By bruce_k
Yes Bruce,
Situated below but slightly forward of the iskra power unit
but just above the 2 fuses covered by a rubber cover.
Switch the truck of at the key switch, hold the rubber cover switch down, switch the key switch on, the steering will shimmy a few times keep holding the switch down The BDI gauge warning light will momenterally go red then green. Switch the truck of at key switch leave for thirty seconds, Switch truck back on this should now have cured problem.
Titus
  • Posted 28 Jul 2010 04:27
  • By Titus
  • joined 6 Jul'10 - 185 messages
Hi titus.Ordered and fitted new torque sensor.This now has fixed the juddering motion occuring but the truck is pulling to the right whilst moving.Is there a calibration test that needs to be carried out.Ps there is no fault code showing on dash and yes it is a iskra type.
  • Posted 24 Jul 2010 02:43
  • By bruce_k
Hi Bruce,
This truck sounds like it may be the eqivalant of a yale MP20X If it is a stand on and ride powered pallet truck.
There should be fault codes showing in the BDI gauge.
and the truck power unit may be the Iskra type.
The fault you discribe sounds to me to be a faulty torque sensor or a broken pin locating the torque shaft to the large steer gear.
Regards Titus
  • Posted 15 Jul 2010 03:55
  • By Titus
Stu Jacover Stu Jacover
Chief executive officer, TVH
