Steering cylinder blowing fluid only at max turn.
Hi guys, I just joined here. I have a Clark C500 45 lift truck Serial # 355 2553 2560. I have never had a problem with the steering cylinder before but now when I turn all the way to where the steering stops and the cylinder is at it's shortest it will blow fluid out of the rod seal end with great pressure. No leaks at any other position. I pulled the cylinder and installed new rod seals but I still have the same issue. I do not understand why it blows out as the seals should keep it contained at all times as long as they are i good condition. The rod is not under size with no scoring. Any ideas as to what may be going on with my truck? Thanks for any help you may provide.
  • Posted 5 Jun 2018 01:46
  • By Dieguy
  • joined 5 Jun'18 - 10 messages
  • Michigan, United States
Better to do it right the 1st time then doing it wrong many times.
Showing items 1 - 18 of 18 results.
Thanks too for everyone's imput. It is nice to see others willing to help out. I am posting the link to the manual. They are hard to come by so maybe it will help someone else too.
https://www.clarkmhc.com/OM/O-221/index.htm
  • Posted 13 Jun 2018 03:34
  • By Dieguy
Well, I'm glad it worked for you. Go's to to show that you never stop learning. Tx for updating us, lesson learned. ;)
  • Posted 13 Jun 2018 02:39
  • By bbforks
I have the truck up and running now. After adjusting the stops so the cylinder does not bottom it no longer spikes the pressure so it does not blow fluid past the rod seal. This is all by Clark's design and getting the manual to read is the proof. It is what the manual says and yes it took care of the problem.
  • Posted 13 Jun 2018 02:36
  • By Dieguy
I think that any cylinder with hydraulic pressure pushing the rod out of the bore will leak if the hydraulic pressure isn't governed. I would pressure test the hydraulic pressure supplying the p/s cyl while the cyl is cycling in & out (not dead heading either direction) vs deadheading the cyl in both directions. I guess is the hydraulic pressure is spiking & overcoming the seals.
I'm curious to hear your results after you adjust the throw of the cyl by adjusting the stops. Keep us posted
  • Posted 13 Jun 2018 02:23
  • By bbforks
As I stated before I looked the cylinder all over and found no cracks. I have removed the cylinder and valve again an still can find nothing wrong with it. So.....searched the world over and found a manual I could read on-line. By the book there are 27 steps to correctly adjusting the steering. Step 16 states the cylinder should not bottom at either end and steps 25-27 gives the final adjustments. It builds pressure when it bottoms thus my blowing fluid out the end. There should only be 70-80 psi when not bottomed. You find the spot where it bottoms and adjust the stops to prevent it from bottoming out and building that pressure. Thanks to being an old truck I now have a leak in one of the hoses after suffering the greater pressure. Tomorrow I am getting new hoses and will make the final adjustments and problem should be solved. If anyone else has this problem I hope this information will help them too.
  • Posted 7 Jun 2018 05:07
  • By Dieguy
How much oil leaks when the cylinder hits the stop? I think the o ring has a problem. That should be able to withstand very high pressure.
  • Posted 6 Jun 2018 05:39
Could that be inside the valve that it bolts up to? I see there is a check valve shown on an exploded view drawing right at the end of the cylinder. Item 26.005
  • Posted 6 Jun 2018 01:33
  • By Dieguy
You have to replace the cylinder assembly. They use to be available as a rebuilt. Not sure if they are still available.
  • Posted 5 Jun 2018 23:47
  • By BREWSKI
Brewski,
If it is on the piston then there would be no access to it as the cylinder is a welded assembly. You could cut out the weld to service it but that is just a pain to remove again. Yeah I know I still have to do what I need to to get it all right again.
  • Posted 5 Jun 2018 22:51
  • By Dieguy
If I remember correctly there is a dump poppet on the ram piston the dumps fluid when the ram is at full stroke.
  • Posted 5 Jun 2018 22:33
  • By BREWSKI
Yes but that still does not explain why it only does it at the limit of it's stroke. Is it possible that if the piston bottoms out it is blocking a return passage inside allowing to much pressure to the rod seal?
  • Posted 5 Jun 2018 21:42
  • By Dieguy
I would try another o ring. You can do that without taking the cylinder off if you're tricky. I've done lots of those and there really isn't any chronic problems that they have.
  • Posted 5 Jun 2018 20:41
Yes I got the seals in with no problem. It came with an O ring to fill the U cup as in many hydraulic seals.
  • Posted 5 Jun 2018 19:52
  • By Dieguy
Were you able to get the special seal in place without it rolling over? You could try a O ring instead.
  • Posted 5 Jun 2018 05:40
  • Modified 5 Jun 2018 05:41 by poster
Adams1,
Yes it is an oldie but it still runs great with very little problems. I have no idea where to check the relief pressure or what pressure it should read for that matter. I did mike the rod and it was right up to size with no scoring. It does not leak until I hit the steering limit and that has me confused.
  • Posted 5 Jun 2018 03:31
  • By Dieguy
that is a pretty old truck. you should mic the end of the ram and make sure it is not worn down. and do a pressure test on the steering check relief pressure
  • Posted 5 Jun 2018 03:04
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
I had the cylinder out to replace the rod seals and found no cracks on it anywhere. It blows past the seals as if it is way to much pressure but only at the end of it's stroke. With the new seals in it I never thought that would happen.
  • Posted 5 Jun 2018 03:00
  • By Dieguy
Could there be a crack in the end of the cylinder tube where the seal fits or near that area?
  • Posted 5 Jun 2018 02:55
Toyota 8HBE30
Flesherton, Ontario, Canada
SMV (Konecranes) 4531CC5
July 9-10, 2025 - Birmingham, United Kingdom
Uxbridge, Canada
Daleville, IN, United States
St. Louis, MO, United States
Evansville, IN, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
