Steering arm spline
on my old Clark CY50 No. 03 W 2435 F ,
With engine off I can move the steering wheel 180 deg with no movement of the rear wheels. !
Adjustable rod ends are good & firm (2 rear slight,) & tie rod ends good. But the major contribution is a short arm that is attached to the top of a virtical spline in the rear center of the machine. The spline maybe worn & this arm moves both axially & radially on the spline shaft.
I am not sure what keeps the arm on the spline - Gravity ?, its a bit hard to get in & see.
Usually arms are clamped tight on a spline but I cant see a clamp bolt yet.
Does anyone have any ideas or info.
  • Posted 3 Sep 2008 12:38
  • By tonigau
  • joined 26 Aug'08 - 7 messages
  • Queensland, Australia
I ounces had this problem with an truck a wail back and found to be a combo of things that gear box at the bottom of the column I found the bracket that held it on had broke free from frame. u will need to jack up rear wheels and look down with a flash light with wheel cut al the way one way. Be careful block the truck up The gear box also has a adjustment screw on it to adjust free ply and gear smash. After that u will need to inspect the drag link there is a tie rod looking end and is actually a valve and ports oil and that is the HYD steering then check all 4 tie rod ends and spider and drag link ounces all that u shod had power steering again once all ply is repaird
  • Posted 4 Sep 2008 18:51
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
I should have mentioned that about 40% of the steering wheel play is the PowerSteering ram actuation, so when the motor is running the play is much less but still not real good.
I have degreased around the spline shaft & there is a C clip at the top that holds (stops it falling off is about all) the shaft on the spline.
Maybe the arm (female spline) could be slit & blocks with bolt holes welded on to make it clamp the shaft. This would require specialist welding being cast/forged.
  • Posted 4 Sep 2008 13:16
  • By tonigau
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Toyota 4FD240
Hoist Liftruck F180-36BOX-CAR
