Starting Problem
has anyone come across this fault before ?
Truck will not stat voltage to the lock off valve when wires disconnected, when connected no voltage to lock off valve,
  • Posted 11 Sep 2013 06:07
  • Modified 11 Sep 2013 06:15 by poster
  • By richard_m
  • joined 11 Apr'13 - 112 messages
  • lancashire, United Kingdom
Think I'm stuck on this 1 iv'e got voltage when not connected but none when connected.
  • Posted 11 Sep 2013 19:11
  • By richard_m
If you've put voltage to it and it works then it's not shorted or open.....a regular ohm reading for one is around 70-120 ohms I believe
  • Posted 11 Sep 2013 18:42
  • By kevin_t
Hi Kevin how may ohm should a good 1 read?? I put direct voltage to the solenoid and the valve moves. many thanks
  • Posted 11 Sep 2013 14:45
  • Modified 11 Sep 2013 14:52 by poster
  • By richard_m
Did you ohm the solenoid Coil on the lock off to see if it was shorted????
  • Posted 11 Sep 2013 08:50
  • By kevin_t
Did you ohm the solenoid on the lock off to see if it was shorted????
  • Posted 11 Sep 2013 08:49
  • By kevin_t
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Big Joe PDR30-154
USD7,500
UN Forklift FBR25NQC3
Lift Tek Elecar
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
CEO, Robust.AI
