Starting Problem (clicks only)
Have an intermittent problem with our forklift not starting at random times. Works fine for days, then will click several times before starting. Have had several service calls with no results. Replaced the starter relay to no avail. Any ideas?
  • Posted 21 Jul 2010 02:12
  • By lotr
  • joined 21 Jul'10 - 1 message
  • Connecticut, United States
check the battery voltage if ok check the solenoid pull-out the starter from the unit. make the body of the starter as a ground then connect a jumper cable to the terminal 30 sometimes the terminal 30 looks like a mounted bolt.
Then when the negative terminal are already connected to the ground of the starter so as the positive to the terminal 30 the starter pinion gear will move forward and if it is not replace. And also check the contact tips of the starter it might be worn-out replace it...then inspect the carbon brush of the starter......good luck!
  • Posted 23 Jul 2010 22:09
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
check the frame to enine ground. put your meter on d/c volts and put 1 lead on the battery negative and the engine and crank engine. any reading above 0.3 volts is too much replace cable. same applies to positive cable, check at positive cable and large lug on starter. these are voltege drop tests and are the most accurate way to determine how good the circuit is. the higher the reading the worse the problem. due to the way a toyota is cabled it is possible to have full voltage to the control side and little or none at the starter.
  • Posted 21 Jul 2010 09:48
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
When it clicks check the voltage at the starter solenoid and make sure you have 12 volts or close to it. If so, sounds like a bad solenoid/starter.
  • Posted 21 Jul 2010 05:18
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Michel Denis Michel Denis
Terberg YT220
Unicarriers FHGE35T5S
