Starter replacement
Just got my hands on a hyster h50xl 1989 model. Every now and then when cranking, the starter would just spin and not turn the engine. I figured theres a bad spot or two on the ring gear. A few days after I got ut the starter went out so I removed and took to my local starter rebuild shop and he verified it was bad. I bought a new replacement from him and got it installed. Now it has only cranked it a couple times but made a good bit of noise. The mounting holes are slotted so I have tried it in a couple different locations with no better result. I have ordered a new ring gear so I'm hoping that will fix this issue. Any ideas?
  • Posted 22 Jun 2020 01:01
  • By Jeff_Golden
  • joined 21 Jun'20 - 2 messages
  • Alabama, United States
JeffG.
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
St. Louis, MO, United States
Louisville, KY, United States
ROYPOW
