Start to lift uneven?
This electric pallet jack works great except when I lower it I can see one side is a little higher than the other? Also when I lift it the lower side waits a while before it lifts then both sides will go up together? I looked for some adjustment on the bars and can not see any, the load wheels look about the same size. Does anyone know if there is an adjustment?
  • Posted 28 Aug 2014 08:39
  • By netpreneur
  • joined 26 May'12 - 27 messages
Thanks Ray Tech.
Update 09-12-14 I fixed it, thanks for all of your advices.
  • Posted 30 Aug 2014 05:39
  • Modified 13 Sep 2014 11:49 by poster
  • By netpreneur
Standard fault on 102's...bushings slide out of place at bell cranks. Get new ones and add plastic spacer in between to prevent them from slipping out. Can be done quite easily, pull battery and put truck on it's side. Next common issue is the pull rod stretching it's eyelet at rear. Need a complete pull rod and trail fork. Give serial # to get proper length
Bushings are non greasable
  • Posted 29 Aug 2014 10:17
  • By EasiTek
Thank you both for you advice, I will check it all out. Thanks again.
  • Posted 28 Aug 2014 22:48
  • Modified 28 Aug 2014 22:50 by poster
  • By netpreneur
the most common things to look for on these pallet jacks that have non-adjustable linkage is bent torsion bars or bellcranks being twisted from lifting too much weight. Usually one side gives and bends the linkage causing it to lift uneven.
yes it can be rather involved when repairing these.
  • Posted 28 Aug 2014 20:43
No adjustments can be made. Your lifting linkage is worn and requires repair. This can be quite involved depending on what needs replacing.
  • Posted 28 Aug 2014 09:08
  • By stam
