stalling and lack of power
This fuel injected propane gm 4 cyl.. engine lift has been a difficult problem for me, with my limited skills with computer and electronic sensors. The throttle body was very very dirty in the butterfly area. took apart and cleaned and then proceeded to clean with electronic cleaner the variable speed section and stepper motor. reinstalled runs much better however when putting the gas pedal down past half way it quits. starts right back up. If I ease the pedal down it seems to last longer but not always then stalls. many new parts rebuilt cyl head new timing belt and water pump and tensioner etc. plugs wires etc. Any ideas
  • Posted 23 Sep 2020 08:50
  • By Thomas_McCann
  • joined 23 Sep'20 - 2 messages
find a way get it done.
Have you checked to make sure that the exhaust is not restricted? Also, you stated that the throttle body was very dirty. Do you mean gunked up or dusty? I'd look inside of the air hose coming from the air cleaner to the engine to make sure that the engine hasn't been dusted. Run a compression test dry then wet to make sure compression is good.
  • Posted 17 Oct 2020 04:34
  • By LCNIII
  • joined 17 Oct'20 - 8 messages
Zhejiang UN Forklift Co., Ltd
Sue Tomic Sue Tomic
