Skyjack SJIII 3219
Hello
I just purchased a used lift and after getting it home it worked and moved 60 feet. When I went to raise it the thing went up 4 feet and lost power completely.
Fully charged battery
Checked 300 amp fuse
Checked main switch operation
Checked power to solenoid - Good
Control box has no power
Checked all connections
Jumped across the solenoid and pump motor run
Nothing jumps out
Any thoughts much appreciated
Thanks
  • Posted 7 Aug 2019 13:18
  • By Durtydawgs
  • joined 7 Aug'19 - 2 messages
Thank you for the response
Serial #265681
No controls work at all
None of the ground controls or from the control box
Checked switch and emergency shut off and they have no power, but function properly.
Main shutoff has full power and works good and power to motor solenoid, but no control power to active. Manual jumping causes motor to work fine.
  • Posted 7 Aug 2019 23:56
  • By Durtydawgs
First thing, what is the serial number of the unit?
And has it lost ground control ability also?
If the platform is stuck in the air you can manually lower it using the manual lowering **** most likely located in hydraulic motor compartment on a small manifold block near the tank.
If once you lower the platform the unit starts working again the problem may be in the control cable in the scissor assy or associated with the limit switches on the lifting mechanism. If control does not return then the problem is elsewhere.
To operate from the ground:
Turn the ground control key switch to the ground position (if it has a ground control box with a key) and then use the lift/lower button that is either beside the keyswitch on the base control.
Or if there is no key on the base unit it may just be a switch located on the panel inside the hydraulic motor compartment on the flip access cover.
If the ground lift/lower switch works and raises it past the 4ft mark then concentrate your attention to the cable in the scissor assy and control box in the platform control.
If you need any information on your unit you can go to skyjack website and get the service and parts book there in the support section free of charge, their catalog's are open information for everyone, just make sure you have the serial number of your unit handy so you can insure you get the correct information.
  • Posted 7 Aug 2019 22:33
  • Modified 7 Aug 2019 22:47 by poster
Maxlion FB25LI
Maxlion FB30EH
