Shifts to FWD or REV but no power
Upon shifting to FWD (or Rev), I can hear the solenoid on the transmission engage. Pressing the gas, if in a flat area, the forklift will move slighly in the direction of the shift, but it has no power thereafter to move or climb. If I press the gas pedal slighly and release several times while on fwd or rev (seems also,that if I play with the up/down hydraulic) "something" engages and now has power. Upon shifting out and then in again, same problem. Transmission and hydraulic oils are good.
  • Posted 10 Mar 2017 12:53
  • By luis_b
  • joined 10 Mar'17 - 1 message
The problem may be in the transmission control valve. The springs need to be checked.
  • Posted 29 Jun 2025 03:50
  • Modified 29 Jun 2025 10:29 by administrator
  • By marksmith
  • joined 26 May'25 - 17 messages
  • United Kingdom
forkliftmanual.com
Check the inching adjustment as well as inching valve
  • Posted 24 Apr 2025 03:41
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
Hi,
We're you able to solve the problem?
I am in Poland now having the same issue with a g15s
Switches gears finely, on flat surface it moves slowly. Even the smallest hill stops it.
Clutch has been professionally reworked already
Pressure problem I guess
Where to search?
What to have a look on?
  • Posted 19 Apr 2025 16:48
  • By Sebastian_K
  • joined 19 Apr'25 - 1 message
  • Germany
I have the same issue was this sorted?
  • Posted 7 Jul 2021 18:31
  • By Slattery
  • joined 7 Jul'21 - 1 message
  • New South Wales, Australia
You may have a transmission pressure problem which can be resolved very simply. Email my profile for info.
  • Posted 13 Mar 2017 07:02
  • By tom_p
  • Alberta, Canada
