service manual
looking for a service manual for a crown 15 mt or at least a wiring diagram Ive had multiple issues with it lately currently doesnt seem to be charging all the batteries
  • Posted 30 Jul 2020 00:03
  • By Brandon_Howe
  • joined 30 Jul'20 - 1 message
The batteries charge through the normally closed contacts on one of the speed contactors (third speed I think but it has been a long time since I worked on one of these) If you put it on charge and slide the normally closed contacts around you might detect sparks or a change in the charger hum when you get to the bad contact. Don't mess with the F or R contactors unless the wheel is off the ground. It can still run with the door open. The speed contactors are on the right side.
  • Posted 7 Aug 2020 01:03
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
do you have a serial number> I can try to get you one
  • Posted 1 Aug 2020 09:22
  • By richard_cucuta
  • joined 29 Jul'20 - 3 messages
RichardCucuta
See if local dealer will give you access to, customer.crown,com. All manuals are on line there. You will have to have a user name and password set by Crown
  • Posted 30 Jul 2020 00:49
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
  • Posted 30 Jul 2020 00:47
  • By JMC1
Noblelift
