Service codes e009 and e016
Worked on this unit last month and the unit way shutting down intermittently. Found wire push out at controller cable connector. Fixed the problem unit runs fine. Now the operator says the unit shut down service code e009 and c016. Battery sometimes last longer then other times. I can't make this problem act up.
  • Posted 18 Sep 2013 06:33
  • By kerbi
  • joined 24 Sep'05 - 17 messages
Do you know if anybody has the software for this unit?
I had the same issue. It was a short in the controller. Put in a new one, and now I need to program it, but I don't have the program.
  • Posted 7 Jun 2014 02:29
  • By BusyE
  • joined 18 Dec'08 - 44 messages
