Seatbelt safety switch/safety interlock
Hi, I'm new to the site but not to forklifts. As always in the warehouse industry, we have trouble getting people to use their seatbelt. I was wondering if there are any systems out there that have a safety interlock that prevents the lift from functioning unless the seatbelt is fastened. I know most skidsteers have a safety interlock system requiring the operator to be in the seat and have the seatbelt fastened. Seems like a logical solution to the problem of not wearing the seatbelt. The hyster service guy said that there isn't such a thing and I think it would be a pretty simple thing to rig up if hyster indeed doesn't have any such thing. Just wondering what everyone else thinks or if they know of something that is currently available like this. Thanks a bunch!
  • Posted 28 Mar 2009 06:05
  • By matt_t
  • joined 28 Mar'09 - 4 messages
  • Minnesota, United States
Showing items 1 - 19 of 19 results.
melvin, send me a mail richard@fmstech(dot)co(dot)za. I will send you some information on how you can retro fit your vehicles
  • Posted 8 Apr 2010 17:04
  • By FMSRICH
  • joined 25 Aug'09 - 4 messages
  • kwazulu natal, South Africa
Dear friend, i facing some problem like what you have. what i can do is to modify the seat belt with switch just like car. if the seat belt not festering or on, the forklift can be start & traveling.
  • Posted 8 Apr 2010 13:43
  • By melvin_t
  • joined 30 Mar'10 - 3 messages
  • Selangor Darul Ehsan, Malaysia
We have a variety of unique seatbelt solutions at triple w dot forklifttrainingsystem dot com under the products section. Before you retrofit any lift, make sure you improving the situation and I would suggest having a dealer install them.
  • Posted 17 Dec 2009 23:14
  • By Panthertrainer
  • joined 11 Jun'04 - 48 messages
I dont know what the labour law legislation is like in other countries but in south africa an employer has to take every precation available to them to ensure that their employees are safe. In the event of a tip over in a forklift truck the only real safety device is the seat belt and their safety cell. Should a driver be killed in the work place due to a forklift vehicle tipping over would you rather be standing infront of the investigating team telling them that this device was installed and you always encouraged drivers to wear their seatbelt or stand there and use a south african expression "angazi" which means " I dont know"
  • Posted 2 Sep 2009 23:02
  • Modified 2 Sep 2009 23:29 by poster
  • By FMSRICH
All well and good but what stops the operator coupling the seat belt and sitting on the belt??
  • Posted 26 Aug 2009 02:30
  • By tugger
  • joined 15 Feb'09 - 58 messages
  • Berkshire, United Kingdom
Guys we sell a seat belt unit which prevents the driver from starting the vehicle until his seat belt is locked in. It works on almost any vehicle and can use either the existing or a replacement seat belt. I will put details of it on our website soon look up FMS Technology in south africa on the web
  • Posted 25 Aug 2009 21:49
  • By FMSRICH
All good comments guys. I especially like the idea of hooking the seatbelt to a light mounted on the top to alert whether the seatbelt is attached. I certainly agree that it mostly is a management issue but not everyone is blessed with competant or qualified managers. We have ordered the fluorescent belts and are going to give that a try and then if needed we might try an interlocking system. Thanks for the replies guys!
  • Posted 3 Apr 2009 22:49
  • By matt_t
Seatbelt interlock is already available on almost all OEM New Forklift Trucks in USA.
Just not Mandated....Yet!
That is comming soon!
Like Ed said, it is a simple matter of ordering a a seatblet From most of the 3rd party aftermarketters out there.
Just look at the Schematic and I am sure any well qualified Journeyman can figure it out.
Regards,
Doc
  • Posted 2 Apr 2009 13:33
  • By Drlifttruck
  • joined 20 Nov'05 - 106 messages
Lift Trucks all the same, just painted different colors.
Doc
Email: kulsh@forkliftservice.net
Our industry has implemeted a daily safety meeting with various canned topics available. That, along with management and supervisors getting after the operators is...mostly effective.
Still a battle though.
  • Posted 2 Apr 2009 01:41
  • By TradeShowDave
  • joined 14 Mar'09 - 48 messages
I theory you might be correct. But in actuality, explaining the issues involving a OSHA fine to some operators can be like explaining to a 16 year old with a brand new driver's license the consequences exceeding the speed limit or DUI. Some will pay heed, some will heed the rules for a while and will not from the get go.
  • Posted 1 Apr 2009 08:21
  • By johnr_j
  • joined 3 Jun'06 - 1,445 messages
"Have An Exceptional Day!"
so in trucks made now, and sold in the USA, there is a requirement that they have an operator in place or lift/lower and drive are disrupted. this makes a seat switch something that is even on Internal Combustion units. this way you still have motor operation to steer, brake, (etc...), but must be in the seat to lift lower or drive. many also have alarms and or lights for the seatbelt. this makes it almost trivial to wire the seat switch and seatbelt switch in series (instead of the parallel circuits they normally are) thus requiring operator in seat, and seatbelt on before lifting lowering or travel.
The only way I know to prevent an operator from connecting the seatbelt behind him is to explain that OSHA's fine for a routine disabling of a safety device (as opposed to the normal mistaken failure to use a required safety device) can be a multiple of the normal fine, as much as 10 times the fine for failure to enforce the routine use of a safety device. and there can be no arguement that a seatbelt attached but then sat upon is a "routine disabling" of a safety device
  • Posted 31 Mar 2009 21:06
Again the need for such devices is due to local management failing to manage or discipline the workforce. As several contributors have said you can fit the seatbelt to integrate with different truck systems, but they are all flawed. If you interlock with the starter, then once started, the belt can be removed, If you interlock with run, effective BUT what happens if the operator pops the belt latch when he is going along? possibly no power steering, power brakes, (after a few applications), and iof he gets into trouble, reattach the belt, restart and then move, interlock with the transmission, pop the belt when travelling and you are coasting, technically not in control of the truck, and all can be fooled by sitting on the belt!
Best idea is to leave the truck alone, have a flourescent belt rather than black so it can be easily seen as a previous contributor suggested, and have it switching a light on the overhead guard. The light is on when the belt is not latched and the truck has drive is enabled or the engine is running.
  • Posted 31 Mar 2009 06:41
  • By tugger
I understand your "try & see" approach. Just one thing to watch for and that's the operator will buckle the seat belt and sit on it. Have seen that many times before in my travels over 40 years. Good Luck
  • Posted 31 Mar 2009 03:29
  • By johnr_j
Talked to another Hyster service guy and he quoted me a price for an electric interrupt seatbelt. I suppose the other guy just didn't want to do the actual work of putting it in so he told me it wasn't available. Either way I think we might try it on one of our lifts to see how we like it and how effective it is. Thanks for the good comments.
  • Posted 31 Mar 2009 02:39
  • By matt_t
Matt, manufacturers are making the seatbelts easier to use since most late models allow the operator to rotate thier hips in the seat when travelling in reverse. Some of our famale operators claim that there hips are wider and are unable to turn around at all. The older styles were a rachet type that, after a few hours of twisting woud lead to back pain. There is an Austrailian retro-fit product that looks interesting and keeps one side of the belt extended when not connected.
  • Posted 31 Mar 2009 00:59
  • By TradeShowDave
I knew it could be done and it probably has been done. I agree that the seatbelt issue is a management issue and that any employee can find a way around it (i.e a separate seat belt clip not connected to the actual seat belt). We have the orage one on order and will install when they get here but hearing the Hyster guy tell me that that kind of system doesn't exist got me thinking. I do think that it would certainly help in at least making the operator think about the seatbelt and it's use before operating the lift. We also have a new Hyster here that does not have the seatbelt/brake/seat sensor system like described above. Just have to be in the seat and then it will work. Just wanted some opinions about it and you all have given great insight, so thanks!
  • Posted 30 Mar 2009 23:39
  • By matt_t
Not sure why your Hyster guy told you that. The new Hysters and Yales have a system on them that has to be used all in unison with each other. Operator has to be on the seat, seat belt has to be latched and foot needs to be on the brakes before starting. When I was working for the Hyster dealer two years ago it was about three days after we recieved the first machine with that system, when we got the service gram advising us on how the system worked. So we looked like a bunch of pinheads pushing this machine into the shop when we could not make it move.
Now if you want to retrofit some older machines I do believe an aftermarket kit is available. 15 years ago I did it from scratch on 12 machines for Martin Marrietta. Their techies helped me out a little by making a couple of pieces I drew out for them.
If there is a will there is a way and I guess the skill level of the tech helps also.
  • Posted 29 Mar 2009 11:53
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Matt - no doubt it is a good concept but there is hardly a system that a "good" operator can't find a way to defeat it if they don't want to be bothered with it - drives Engineers crazy for sure. The simpler the design the easier it is to defeat. As an example, on sit down rider lift trucks there is a safety seat switch in the bottom cushion to prevent the unit from function without an operator present. A simple GEM or any other brand paper clip can defeat this.
Years ago Ford Motor Company required all their lift trucks to be fitted with an "inch pound" overload device to prevent the trucks from being overloaded. Mind you, that when they bought a truck to be rated 8000 lbs. per their safety standards (much greater than the ASME/ANSI standards) normally a 10,000 base rated chassis was required. They spent about $2000- 2500 per truck for this required optional safety feature. Between the operator's trying and succeeding in defeating the systems and the suspected reliability of this safety option it was dropped as a requirement in the Ford safety standards in a few years.
In my opinion, having the operators wear seat belts is a management issue.
A very simple option available is seat belts with bright orange straps in lieu of the standard black belt. This makes it much easier to visually police who is and who ain't wearing them.
  • Posted 28 Mar 2009 22:29
  • By johnr_j
There is seat belt kits availale with a safety interlock fitted. They are available from TVH.
  • Posted 28 Mar 2009 18:34
  • By danny_k
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hangcha CBD15
China
USD1,600
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
USD1
Hangcha CBD15
China
USD1,600
